Blocking Layer 7 in MX not working but Logged
EdgeFarming
I`m blocking some apps in Layer 7 Firewall (Youtube, Instagram and Sports)
They are never blocked but you can see the match in Event Log, Why? Am I missing anything? Thanks
6 Replies 6
michalc
Hi there,
Could you clarify what is not being blocked? Are the clients using web versions or apps on their phones?
If apps on the phones than the QUIC protocol is being used. I'd recommend blocking UDP 443 using L3 but please check for collateral damage.
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
EdgeFarming
Hi Michalc,
None of them, youtube, instagram, and any sport page like. nba, nfl, nike, etc.
Clients are using we version.
michalc
There's been a lot of similar topics on the forum regarding this with accepted solutions.
Please see some of those threads below
2
3
Mloraditch
Do the clients in question have an overriding group policy? I wouldn't think so based on the logs you've shown, but that's the only thing that should override the Layer 7 rules. If not it sounds like some sort of bug you would need to contact support about.
Layer 3 is also processed before Layer 7, but I don't believe you'd get that log entry if you somehow had a layer 3 rule overriding the layer 7
You sound familiar but here is the reference documentation: https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Creating_a_Layer_7_Fi...
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Layer_3_and_7_Firewal...
EdgeFarming
Hi Moraditch,
I dont have any other policy overriding this one, I'm trying to show firewall policies to a customer but they dont work at all.
I quite like using layer 3 FQDN firewall rules.  Then just block access to the DNS name "youtube.com".
