Blocked sites
DominicMcGlinn
Blocked sites
G'day I was hoping to figure out how to find out which clients are triggering the below. Is there a report that tells me which clients are doing this? This is from my Summary report for the mx84
Top blocked sites by URL
URL
Category
# Sites[Sorting down]
 % Sites
1geo2.ggpht.comMalware Sites5528.1%
2crl4.digicert.comMalware Sites5226.5%
3tpc.googlesyndication.comMalware Sites3417.3%
BlakeRichardson
Will the below in the event log help?
5 Replies 5
BlakeRichardson
DominicMcGlinn
you sir are a prince among men.
BlakeRichardson
Happy to help!
ITPointeMan
I've used this solution as well. Do you know if anyway to search by category. Combing through all of the Content Filtering events is tedious.
For example, If I have a percentage of sites being blocked by the "Adult and Pornography" filter, can I filter specifically for that category in the event log?
Thank you for your help!
BlakeRichardson
@ITPointeMan If you export the log to a CSV you should be able to filter these down in Excel. The log does show the category for the blocked traffic so this will work.
