We are using MX65 at sites which give out a DHCP address which allows lan connections to get to the internet via the MX65
Is there anyway I can block all connections except the ones I authorise without using 802.1x? I want to stop users just plugging in pc/printers into the MX65.
Solved! Go to Solution.
Couldn't you just disable the unused ports?
Isn't this the whole point of 802.1x? I.e If a client doesn't authenticate it doesn't get an IP/Connection? Therefore devices which can't authenticate via a wired connection regardless if it's a printer/laptop/pc won't get internet connection
Have a read of this knowledge base article, it also gives you examples of how to configure - https://documentation.meraki.com/MX-Z/Access_Control_and_Splash_Page/MX_Access_Policies_(802.1X)
Adam - I use a standard switch connected to the MX65 so cannot block every port
WANKiller - I realise I can use 802.1x, but didnt want to goto the expense or hassle of implementing 802.1x
On previous firewall I have used you can just authorise MAC addresses
Only somewhat inexpensive option I can think of then would be to get a small Meraki switch so you can go back to MAC authentication. Otherwise 802.1x is the only other feasible option but far more complex.
Looks like I forgot to hit post on this yesterday. There is a easy way to do this, but requires a bit of setup.
Now that you've done all this, for any client you want to allow Internet access, just assign them a group policy. If someone tries to plug into the MX device and they do not have a group policy assigned to them, they will not get Internet access. If you know the MAC address of the device prior to them connecting, you can add it under the clients page and assign a policy so that they will have access right away.
Thanks MR-IT-GUY, that will work.
