Best practice to remote into a win11 workstation behind an mx67w
mnb22
Just browsing
  I have a workstation running windows 11 (sitting behind an MX67W appliance) and would like to know if there is a way to VPN into that workstation through the mx67w appliance from the internet.  I would like to use that workstation as a jump host and RDP into different workstations as a remote access method.
I don't want to RDP over the internet (using port translation) so I thought the VPN route would be a way to go.  I see that Cisco has a "Client VPN" feature but am not entirely clear if this is for the aforementioned purpose.  If anyone has some useful thoughts here I'd really appreciate if they could reply to this.
Kind regards,
Mike
Brash
You're correct that you would want to use a VPN instead of exposing RDP to the internet.
Your high-level process would be:
1. Authenticate and connect to the on-premise environment over VPN
2. RDP to your Windows 11 computer
You can use either the Meraki L2TP Client VPN, or use Cisco Anyconnect (additional licensing is technically required).
Client VPN Overview - Cisco Meraki
AnyConnect on the MX Appliance - Cisco Meraki
If you only want to be able to access the windows 11 jumphost, you can restrict VPN users to only access this host - Restricting Client VPN access using Layer 3 firewall rules - Cisco Meraki
For me the Anyconnect is the best way.
https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance#Overview
Brash
mnb22
Just browsing
This helps validate the approach.  Thank you!
