Azure VWAN and Meraki (Whats the big deal)
Tadpole86
I am trying to understand what the Azure virtual WAN offers to customers. From what I understand the vWAN solution from Azure is an alternative to the Meraki VMX100 for connectivity to your IAAS resources.
Meraki Documentation -https://documentation.meraki.com/MX/Deployment_Guides/Cisco_Meraki_MX_Branch_to_Azure_Virtual_WAN_De...
From what I understand vWAN is a connectivity piece that simplifies vNET to vNET routing. (How was this done before vWAN?)
One negative thing that I have noticed is that you use the Meraki 3rd party VPN to connect into the VWAN which means that you are only using one VPN tunnel. When connecting to a VMX in Azure from a MX using SDWAN you can utilize both WAN links at the MX site.
This question comes from a lack of familiarity with Azure, is vWAN really such a big game changer? Was routing between Vnets really that difficult prior to vWAN.
Does vWAN offer anything else I am missing?
0 Replies 0
