Does Meraki MX supports Azure VPN with Basic SKU VPN Gateway.
Azure VPN Gateway configuration has an option to select SKU - https://docs.microsoft.com/en-us/azure/vpn-gateway/vpn-gateway-about-vpngateways
From my observation if Basic is selected, Meraki would not form S2S tunnel.
If any SKU above Basic is selected, Meraki MX forms S2S tunnel successfully.
Any idea why Meraki MX is not able to form S2S tunnel with Azure for Basic SKU.
Azure VPN SKU mentioned here - https://docs.microsoft.com/en-us/azure/vpn-gateway/vpn-gateway-about-vpngateways under "Gateway SKUs by tunnel, connection, and throughput"
