Autoupgrade to MX16.16 and tunnel doens't work correctly anymore
Thane08
Dear,
We have a Fortigate 1200D on 1 side and a cisco meraki MX84 version 14.53 on the other side.
The tunnel works fine now but when we upgrade to 16.16, doesn't work for some parts. The tunnel has status up but traffic from the fortigate is only allowed to 1 vlan of the cisco meraki.  There is no firewall policy blocking this traffic.
Because when we start traffic from cisco meraki from another vlan, we can ping from the fortigate to that new vlan.
When we rollback everything is back to normal.
Anybody with the same issue?
Kind regards
Thane08
I changed ikev1 to ikev2 and now it's working again.
The RemoteID became mandatory from 15.x and up.  For 99% of cases, this will be the IP address configured outside your Fortigate (usually a public IP address, but it could also be a private IP address if the Fortigate is sitting behind something doing NAT).
Also, I think DES got disabled at some stage, in case you have ti configured to use that.
Thane08
Hey,
Thanks for replying.
We use external IP adresses for both firewall.
We also don't use DES.
On the fortigate firewall I don't see any incoming data
But the tunnel phase 1 & 2 are up and running.
We do use a VDOM (other than root) for this client on the fortigate.
Thanks in advance.
Thane08
