@Sleiman If you use Auto-VPN over the L2 WAN then it connects prior to NAT so the LAN IPs from one site are seen at the other site. In terms of the WAN IP shown in the dashboard, they all show the central site corporate internet connection IP.
This may well be different if you have one WAN on public internet and one WAN on private WAN.
If you don't full tunnel over the auto-VPN then yes the WAN port IP from the site is how the traffic appears to the corporate firewalls, you can disable NAT on the WAN port in MX15 to fix this.
