Application of a Data Cap on Meraki MX link or MG
TBee
Is there a way to apply a data cap on one of the WAN links on a Meraki MX or MG.
Basically we are proposing a SD-WAN solution, which will use a broadband primary circuit and a 4G Secondary, via a MG (might have to use the customers existing gateway).
On a normal day it is expected that both links will used to carry traffic. However the 4G link has a monthly allowance, that based on analysis of use, shouldn't be exceeded.
Is there a way of either monitoring and alerting on the usage of the 4G link, at say 80% or applying a cap an alerting?
I can't see it on the dashboard for the MX and don't have visibility of an MG to check.
1 Reply 1
GreenMan
There's no way to do this natively within the Dashboard, that I'm aware of.   You would be able to monitor cellular usage, however, via the API - you could then trigger additional API-based controls, once usage reaches your preferred threshold(s):
https://developer.cisco.com/meraki/api-v1/#!get-network-appliance-uplinks-usage-history
Perhaps by progressively stepping up cellular firewall rules, as the limit approaches - maybe ultimately allowing only the most critical / bandwidth thrifty applications?    https://developer.cisco.com/meraki/api-v1/#!update-network-appliance-firewall-cellular-firewall-rule...
