AnyConnect keeps popping up even when not accessing VPN
JordanCN
I am using the latest posted 4.10.05085 AnyConnect client to connect to my MX-84 units.  Occasionally the AnyConnect client will pop-up on its own.  I have to verified the reason, but it may happen when it sense some sort of connectivity change.  This occurs whether or not the client is trying to get on the VPN and even when they are in the office.  Maybe a few times a week.
I have two questions related to this.  First, is there a way to stop this from automatically popping up?
Second, question is just me being very picky.  I have used the AnyConnect many times over the years and I only seem to recall the AnyConnect GUI appearing in the lower right corner of the screen.  Now it pops up in some random spot on the screen. Is there a setting for keeping down in the corner?
8 Replies 8
I have had others report this behaviour to me.  I haven't personally experienced it.
I wonder if we forcibly disable auto-reconnect in the profile if it will stop it from happening.
CMTech1
Ran across your question and figured I'd mention we found a fix for our Meraki/Cisco AnyConnect flapping issues.
Anyone using the Meraki Cisco AnyConnect issue where it bounces a few times after initially connecting should ask Meraki support to review the VPN Client MTU's. We had them adjust the MTU's for this and no further issues with users now either. Due note, this was with our vMX VPN client in Azure that had this issue since the on-prem MX's were fine.
Hope this helps....Cheers!
glenn3
Did you ever get to a solution on this one?  We are also running 4.10.05085 and this same symptom is happening.
JordanCN
Still no resolution.  However I have linked it to computers that are having issues where a device randomly disconnects and reconnects.
I and users have heard Windows make the device disconnect sound and then immediately make the reconnect sound around the time the AnyConnect window pops up. Most of the time it is the Realtek NIC that flakes out for a second several times a day.  This is very painful because we use several programs that have SQL back ends and they can't handle the random temporary disconnects without bumping the user out of the application.
adamruncie
Not to resurrect a dead thread here but did anybody find a solution on this?  We're seeing the same behavior on our network, which is completely a Meraki stack:
- MX250 running 18.107.5
- MS225 running 15.21.1
- Meraki MR42's running 29.6.1
Endpoints are mostly Win 10/11, running Cisco Secure Client (5.1.0.136) with the Secure Endpoint and VPN Modules.  We also utilize Cisco Umbrella.
Our corporate wifi utilizes Meraki Systems Manager Sentry configuration, and this seems to be the only wifi network that exhibits the behavior.  If I connect my laptop to my Guest wifi, my Secure Client does not pop up.  When I join back to my corporate Wifi it tends to pop up, but not *always*.  Seems to be most common when I first come in during the day and have had my laptop connected at my home wifi in between.  We do have a walled garden configuration in place to allow some communications while the Sentry evaluates the end point -- things like O365 and such.  Is there something that we should maybe put in the walled garden that might eliminate this popup?
JordanCN
For us, we had to Disable Captive Portal Detection in our AnyConnect client profile.  That seemed to resolve the issue for us.
adamruncie
Roger that - we'll give it a shot and see where it goes!  Will report back for posterity.
mikabrownrm
Same issue here.  Really pissing off the users.  We have Disable Captive Portal Detection "enabled" and still have the issue.  It still pops up when in the office behind the MX.  Does seem to happen when network connectivity changes occur.  AC event logs indicate it's still trying to contact the portal.
