AnyConnect VPN
RahulPrasadh
AnyConnect VPN
I have a question about AnyConnect on the iPhone. When I install, configure and run it, I get a message about the server being untrusted. I disabled the "Block untrusted servers", and I get the message that Cisco Secure Client cannot verify the identity of the VPN. Would I like to connect anyway? Is there anything we can do to prevent this message? It will just cause confusion among our users.
2 Replies 2
KarstenI
Without knowing your setup, it is only a guess. But it is likely that you don't use the FQDN that is shown in the AnyConnect config page but your own FQDN. Use the Meraki FQDN and you are fine.
GIdenJoe
Normally if you configured your Anyconnect on your MX with using the certificated provided by Meraki, make sure you connect using the dynamic-m URL and NOT the IP address.
The autogenerated certificate uses the dynamic-m name as CN and that cert should be trusted by most OS'es.
