I have a meraki MX75 connected to an MS120 switch.
I have a printer connected to a switch port set to VLAN 1 in trunk mode.
Rest of the devices are on VLAN 20 and VLAN 30 (both wired and WiFi).
I want devices on vlan 20 and vlan 30 to be able to access the printer. How do I do that?
Solved! Go to solution.
You are correct, I had a different issue that prevented access.
My next question: I also have a remote teleworker. When connected, they access to VLAN 30 only. How can I give them access to VLAN1?
Thanks, that solved it!
I am new to Meraki....
