Alerts on WAN2 down ??
AlphacomItalia
Hi, there is no alert for the wan2 fault/down? there is on ly "The primary uplink status changes" but if WAN2 go down and i I don't notice, when primary uplink have a problem I'm screwed because wan2 is down too.
MyHomeNWLab
It can be set in "Insight > Alert" menu.
Meraki Insight or Secure SD-WAN Plus license is required.
As long wan1 or wan2 is up there is no message.
Only thing (i know) you could do is build something with the api yourself
Ryan_Miles
Meraki Employee All-Star
Unfortunately you need Insight which allows for per WAN alerts to be configured.
MyHomeNWLab
