After update firmware 16.16 DNS server or interface wan doesn’t solve URL meraki.brightcloud.com
Guerino
Hello everyone,
We are facing issue with firmware 16.16 to solve URL meraki.Brightcloud.com when DNS of interface wan is configured with dynamic ip address 192.168.x.x same ip address from default gateway of modem upstream. This issue generally have been happening with specific service provider from Brazil. This behavior is stranger because the same dns server 192.168.x.x can solve the URL meraki.Brightcloud.com on firmware 15.x. This behavior we have noted on packet capture. When the issue appear the customer can’t navigate on internet our their application via Auto VPN. It looks  like the MX has stopped working. We have updated till the firmware 17.x and the behavior is the same
Let me know if someone have faced this issue
Best Regards
Renato
4 REPLIES 4
I think it's not an MX issue, I performed a test outside of a Meraki network and I couldn't access that specific URL either.
Hello  Alemabrahao,
You can´t reach out this URL. I´not sure, but this URL is used to populate content filtering Meraki bases till the firmware 16.16.7. From firmware 17.10.2 last stable the MX uses Cisco Talos. Sorry I´m not clear or if I have spoken something wrong.
Yes, I know about that. As you said in version 17.x they don't use Brightcloud anymore, so I think it's not a version issue. I'm using version 16.16.7 and content filtering has been working well.
Guerino
Hello Folks,
The issue was fixed on firmware 17.10.2.
Thank you for all
Renato
