Addressing VLANs template subets
meraki-user
All of the documentation I've read says that when you create a network template, you can tell it what range of IP addresses to use for the subnets on the MX Addressing and VLANs page. For example, giving it the range of 10.5.0.0/16 and telling it to create /24 subnets from that /16 block. When I create a template, or edit an existing template, there is no such field in the GUI. Is there something I have to set somewhere to make that field available?
Go to addressing and vlans
Routed mode
Select vlans (not single lan)
Click a vlan
Select unique
Routed mode
Click a vlan
Select unique
meraki-user
Thanks, that was what I missed. In my GUI, the "unique" button is right under the "Dual Stack Config" label, so I overlooked it, thinking it was some IPv6-related setting.
There are are some important documents to check.
https://documentation.meraki.com/General_Administration/Templates_and_Config_Sync/Managing_Multiple_...
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
