- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Adding too many blocklist URLs in Content Filtering
I have thousands of URLs that I need to block in content filtering (around 20,000) will this put the SD WAN under too much load in anyway and affect performance?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@TLO3346 : there is no such limit define of the number of the URLs to be blocked as per my knowledge. I would say you try it and check experience !
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
So far, no issues.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@TLO3346 : Good luck !
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This one's a popular internal question with newer people on our support team, so just for some additional context here: the pre-loaded categories contain hundreds of thousands, up to millions of URLs. Unless you're really determined, you're not likely to ever be able to outpace any of those 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@AlexP : Yeah correct, Hope @TLO3346 checked on pre-loaded URLs as well.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This seems like an old school way of doing things. Any reason why you can't use the built-in content filtering and threat protection system which dynamically updates without you having to do anything?
It's probably doing something similar, but better.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Built in? Do you mean the category filtering?
The screenshot is of Content Filtering URL filtering.
Was told by company to do it.
