@ByDesign1977 wrote:
Hi
@Adam, can you just clarify, Option 15 is the domain name:
custom 15 Text mydomain.co.uk
Option 66 is the IP or name of the PXE enabled server:
TFTP Servername (66) 66 Text myservername
With this, your boot options are disabled and you are able to pxe boot without issue?
Many thanks
Correct with the above settings my phones boot no problem. We originally migrated from a WIndows DHCP server and those were the only settings I needed to move over to Meraki to make it work. Option 15 is the DNS domain name. So if the device were to ping AD it would resolve to the FQDN ad.domain.com. Option 66 is our TFTP server.
