AWS Direct Connect + Meraki BGP
Our ISP has recently provided us with a L2 AWS Direct Connect connection. We are required to configure the BGP side of things to get this link operational.
Is the BETA BGP Meraki implementation stable?
Has anyone configured a AWS Direct Connect connection using their Meraki? Was it fairly straight forward?
Cheers, M
4 REPLIES 4
Re: AWS Direct Connect + Meraki BGP
Curious: What size of AWS DX are you doing?
@Welles - Just a 100MB
Further to my original question - If I was to have 2 WAN interfaces will this be configured for:
1. Both interfaces?
2. WAN 1?
3. Select which interface you want?
Hi.
We have recently install or added a vMX100 to our AWS VPC. It was straightforward as long as you remember to use the token within 1 hour 🙂 "Read the documentation if you don't know better" :-).
There are some limitation on what you can do but it was not a showstopper in our case.
I have only hear rumours regarding Meraki will start supporting BGP features . That will be great since that will mean we can get a fully HA setup towards AWS instead of this single point of failure. So good look.
Best Regard
John
