API: network traffic - need help
vdurgad
The API GET/networks/{networkId}/traffic?timespan=7500 returns an empty array. I have a network with some clients and have traffic analysis and hostname visibility enabled a couple of days back. I see some data on the Traffic Analytics page on the UI but this API doesn't return anything. I tried with multiple timestamp values but no use. Any help in this matter would be appreciated.
5 Replies 5
jdsilva
Can you provide the complete code you're using? With API keys and Network ID's scrubbed of course.
Nash
As @jdsilva says, we really need to see your sanitized code.
Sometimes things like this are due to typos that you can't see yourself or something else missing. I recently wasted 45 minutes on something because I didn't realize I was using requests.put instead of requests.post, for instance. 🙂
vdurgad
Thanks for the quick response 🙂
I am trying this in postman. This is exact URL with method GET https://api.meraki.com/api/v0/networks/{networkID}/traffic?timespan=7200.
Headers:
X-Cisco-Meraki-API-Key : {key}
Content-Type : "application/json".
and response.
Nash
Okay, when I test that one out, I get back:
    "errors": [
        "Traffic Analysis with Hostname Visibility must be enabled on this network to retrieve traffic data."
Because, well, hostname visibility isn't... enabled... on my test network. 🙂
So you're not getting that, you're getting empty? What's the return code you see?
I tested it using the Launchpad API key and I get returns that way, and the above 200 OK status.
What happens when you use the Launchpad API key?
vdurgad
Yes, the status is 200, I enabled the traffic analysis and hostname visibility. So was wondering if there is a min threshold data needed for the API to show some response? because I see some data in the UI (unless the corresponding APIs are different)
