AMP update interval
Charlie
AMP update interval
Does anybody know if the AMP -Sourcefire SNORT integration is real-time?  I mean will it provide zero day type of response to a malware source?  Maybe better said, is there an update interval set in the AMP integration that gets updates on a schedule?  Or does it constantly pull it down?   TIA
Check this out:
https://documentation.meraki.com/MX-Z/Firewall_and_Traffic_Shaping/Traffic_Shaping_Settings#List_upd...
It defaults to "hourly".  You can also change this to "daily" or "weekly".
I don't know the answer for sure.  I think it is either hourly or daily.
Check this out:
Thanks I did run across that but initially it looked like a setting for the uplink stats to 8.8.8.8.  But definitely pointed out in the documentation and also when you hover over the (i) icon in the dashboard, I see where it says applies to security updates including Malware.  Thanks PhilipDAth!!
