We have several internal applications that end users reach over the Meraki VPN tunnels. When we enable AMP we get timeouts on several different parts of the application. This is not a bandwidth issue. The moment we bypass AMP users do not have a problem. There is no logs of these connection failures that I can find on the MX appliance. Support has suggested packet captures but the problems occur so fast that I have to get the users back into the application fast so while i'm waiting to get those I wanted to reach out to the community. Some of the connections are over ports 21/22/80/81/443/8443
Thank you
Solved! Go to Solution.
If it is AMP blocking then it _should_ appear under Security appliance > Security centre under the Events tab. Note that I say _should_ ...
You could also just whitelist your internal applications in AMP under Security appliance > threat detection.
And last thought, what version are you on? We've had much better AMP performance / results up in version 14.x than in some of the older firmwares.
There was a lot of improvements in AMP in the 14.x code. If you are not using it yet, I would suggest using 14.30.
Thank you PhilipDAth as the other poster said the same thing I will do the upgrades.
@RogerO wrote:
my internal apps team which they do not know what URL's they call
I'd act surprised... But I'm not.
Man, life would be so much better without developers 🙂
Still no fixes for several known AMP issues, even with the latest 15.x that you need a support engineer to push. AMP is not going to be internal application friendly for quite sometime, based upon my experience with our internal SharePoint sites and forms, and a fix still not available in even the lastest beta.
Can anyone from Meraki please help us out?
Thank you I will have to check and see. I'm in the middle of sourcefire upgrades at data centers so apple/orange in progress.
