Has anyone had issues with the Meraki MX67C failing over to the 4G SIM card? We are unable to get the router to detect the SIM that installed.
This might seem dumb, but can you put the SIM card in a phone and find out if the card is working properly?
same quastion.
Thats interesting....
We've been battling a few MX67's that don't like their cellular connection.
We've done a dance, told them a story. Powered them up and down and they don't want to play ball....
Hopefully not an RMA situ!
Note that the MX67C may need a firmware upgrade before being able to use the cellular function for the first time. So make sure you plug it into a wired connection first.
