3rd party Instability
rsage_voda
I have a MX95 with a fixed line Internet connection on WAN 1 and a Starlink on WAN for backup. The MX is set to no load balancing with WAN 1 as Primary.
The VPN is also not not configured on WAN 2 until it goes active.
There is 3rd Party VPN to Azure over WAN 1.
There has now been two reported issues with instability with the VPN which coincides with an issue on the Starlink.
The instability continues until the Starlink is rebooted
I am wading through the event logs. Any advice gratefully received.
1 Reply 1
rhbirkelund
Can you confirm with the other end of the 3rd party VPN, that they are building a tunnel towards the WAN1 uplink. and not WAN2?
