Search instead for
Issue adding an MV camera to existing network that is bound to Template
Can you add a Camera to an existing network that is bound to a Template.  I am getting the following message.
"A bound combined network may only contain bound networks"
2 REPLIES 2
Re: Issue adding an MV camera to existing network that is bound to Template
I recall having this issue once before with adding an MR to a bound network.  It was bizarre, because I was adding MR's to many of the networks, and just one of them had this issue.
In my case support got me to unbind the network, add the MR, and then rebind it.  This solved my problem.
Make a note of the IP configuration (if using unique address) before doing this, as you'll need to reinstate this afterwards.
MV's don't support template binding... I wonder if that's why?
