Remove organization
arom
Remove organization
Hi team,
We had a ongoing Secure Connect trial which we are not using anymore and want to delete but are unable for some reason. The error says that there is "still networks" configured but that is not the case since there are no networks configured at all.
Do you have any suggestion? Im not sure how to contact support and have them remove it in backend instead.
rwiesmann
In your meraki dasboard organization...don't you see any networt?
Left side click on Network and then on view all networks
If not...you can open a support case on the ? top right of your dashboard => Get help and cases
2 Replies 2
rwiesmann
arom
oh i noticed why i couldnt register a support case, its since the trial dashboard dont have any license 🙂 so i' create the case via another dashboard.
thanks for the help!
