AnyConnect 5.1.7.80 Installation Issues
Serion
Is anyone having issues with installing the Cisco Secure Client on a Windows 11 24H2 machine?
I run the install and everything looks fine, no errors, and get the installation finished message, but the program does not install.
Tried everything to get it to install with no luck.
2 Replies 2
Mloraditch
I have not seen anything, there is a public Webex Teams Room for the Secure Client. I don't see any questions similar to yours recently, but you can join and post your question there as well: https://eurl.io/#TmrReXaEj
JustLurking777
Did you find any resolution to the problem?  I'm having the same issue with both AnyConnect and Secure Client installations?
