Upgrading to wifi 6 AP’s
speakerfritz
As  luck would have it, as soon as I bought my gx-20 and wifi 5 Meraki go equip, they came out with a gx-50.  Which I bought.  The gx-20 is in a someday drawer.  Someday I’ll find a use for it.
and as luck would have it, now there is a wifi 6 AP.
so now after doing some reading and reviewing my usage needs, I ordered 2 wifi 6 AP’s to replace the 2 wifi 5 AP’s I just bought.
so 2 more things to put into the someday drawer.
speakerfritz
I was t sure if going from wifi5 to wifi6 was worth the cost and time….but…wifi6 is blazing fast if you have a gx-50, a switch, and the wifi6 ap’s
1 REPLY 1
speakerfritz
