Static IP routing to internal host through GX?
Dean_R
I have an exec that has an internal security camera system in his house that is accessible from the Internet via a separate static IP address. Am I able to add the ISP assigned IP block to the GX and then route one of the addresses to the security system? I have seen where you can do port forwarding, but I was hoping for static IP routing.
AMP
@Dean_R
I believe you are referring to a 1:1 NAT in which case the GX20 does not currently support. We would suggest submitting a feature request to support 1:1 NAT.
Knowledge is power
1 REPLY 1
AMP
@Dean_R
Knowledge is power
