Hello @KevinW
You can only set the maximum limit on Meraki GO. There is no option for a minimum bitrate.
This would be under Traffic shaping when you look at the Settings page of the wireless network.
You can set the limit by selecting one of the options
You can select the limit by moving the green dot.
Cheers
