Meraki and GX20-HW PPPoE - configuration for CHAP authentication
Balrog
I have GX20 which doesn't seem to work with PPPoE. I am trying to fault-find this for a colleague. My network normally runs on Cisco ASA hardware - I have a known good PPPoE connection. I have entered the username and password but the GX20 refuses to work. The only result from Google is a comment that GX20 is great provided that you are NOT using PPPoE. The GX20 'Uplink Configuration doesn't have any option to choose between pap and chap which is where I suspect the problem lies - anybody know otherwise?
1 Reply 1
Artic6
This is currently what I am trying:
Username : bthomehub@btbroadband.com
Password : bt
Connection : PPPoE
VLAN :
I get exactly the same problem as you however if I use my Google nest router, everything works absolutely fine
I can see my OTN Modem keep disconnecting and reconnecting the port so I would imagine as you say the Meraki is using the wrong username and password authentication
I have added this to my ticket I have with Meraki
currently to get this working, I have to have my Google nest Wi-Fi router in Bridge mode connected to my Meraki router then I have access point connected to that…..
I do not like the fact I require three bits of hardware to get my network online whereas if I remove Meraki, I only need one.
