Guest isolation on a Bridge network?
Beavis-DCS
It doesn't appear you can have guest isolation turned on when running a Bridge network (only enabled on NAT). Are there plans to allow isolating clients on a non-NAT network?
My guest network is already on a separate vlan to my main network, and I'd rather not double- NAT if it can be helped.
Cheers!!
Accepted Solutions
hidden0
Meraki Go Team
Re: Guest isolation on a Bridge network?
Hey @Beavis-DCS
That is a valid point. I believe it would be an easy lift for us to allow the Communication Between Devices toggle be allowed for Bridge mode SSIDs. This way, while bridge mode was selected, you could still opt to block all LAN IPs from talking to each other. Would that fit the bill?
2 REPLIES 2
hidden0
Meraki Go Team
Hey @Beavis-DCS
Beavis-DCS
Yes that would be ideal. Thanks!
