Trying to get ahead of a new customer install.
ISP is providing 900Mbps service, standard PPPoE.
Whilst the GX50 can handle Gigabit connections, the throughput is 500Mbps given FW feature, clearly there is a gap between 900Mbps and 500Mbps, therefore how does the GX50 handle the overrun for a short period of time? Is it a case of buffering or are packets simply dropped?? If it is buffering how much can be buffered??
Any thoughts or experiences welcome.
Thanks,
I speed tested my gx50 from ports on the gx50, ports on the 1sst switch, devices connected to APs. from physical ports I got 800mb. from APs I got 300mb.
interesting statistics. Are you running MG access points?
yes
meshed
i suspect if unmeshed, thru out from APs would be higher.
Yes it would be for sure
I have been testing today, pulling together stats but throughput within router is not easy to identify as it would be with enterprise/carrier class platforms
I have this exact same question! I am thinking about buying the GX50 however my ISP is providing me 800Mbps — does that mean that if I buy this GX50 that I will basically be giving up 300Mbps in speed and my new speed would be only 500Mbps??
I don’t understand why Cisco would bottleneck the speed so much. Most people get nearly 1Gbps from their ISP these days.
What are your thoughts on what I should do? Today — My network is ISP CO-ax to Modem ~> Google WiFi Mesh 3 Pack routers. No firewall or any switch.
I had 1gb fiber but after doing some testing and getting 500 to 600 my on the gx50, I down graded to a 300mb fiber connection.
I could not get anything more than 600mb thru the gx50 and that was with a wired laptop.
This is correct. GX limits WAN throughout to ~500. Anything above that will not be utilized. This is hard capped at a FW/HW level and known throughout the entire Meraki SD-WAN line.
If you want to utilize full throughput, you'll either need to purchase a different firewall or downgrade your connection speed.
