Hello.
I can't seem to find the desired log display, so I don't think it's supported.
トラブルシューティング - Cisco Meraki
メラキ ゴー - WiFi アクセス ポイント機能の詳細 - Cisco Meraki
Meraki Go - Troubleshooting Tools - Cisco Meraki
Configuring Notifications in Meraki Go - Cisco Meraki
This function is compatible with higher series Cisco Meraki.
FAQs - Meraki Go : Meraki Go (meraki-go.com)
>WHAT’S THE DIFFERENCE BETWEEN CISCO MERAKI AND MERAKI GO?
Meraki is an enterprise-grade cloud management system. Clients include colleges and universities, retail and restaurant chains, hospital systems, and sporting venues like SoFi Stadium.
Meraki Go provides a simple, secure, and smart networking solution for small businesses. The cloud-based system empowers business owners with a reliable system they can easily install and manage themselves. Meraki Go is sold directly to customers through partners like Amazon.
Meraki MR requires a separate license, but please consider using it.
MR - Wireless LAN - Cisco Meraki
有用な回答だと思われる際にはkudoをクリックして頂けると幸いです。
回答があなたの問題を解決した場合、accept as solutionをクリックしてください。
