Do Mesh repeaters support wired clients?
watdee
Can I extend my LAN by plugging in wired clients to the ethernet port of a meshed meraki go AP in repeater mode?
GoJoe
Meraki Go Team
Meraki Go Team
Hey @watdee,
Meraki Go currently doesn't supported extending the LAN via the ethernet port on Meshed Repeaters. Feel free to submit this as feedback from within the Meraki Go App!
Cheers,
Joe
3 REPLIES 3
GoJoe
Meraki Go Team
Meraki Go Team
Hey @watdee,
Cheers,
Joe
watdee
Thanks for the info. I currently need that feature so will have to hold off on trying them.
While not required many times, we frequently run into situations where it is nice to be able to plug a device (or even a switch with multiple devices) into the LAN port. This is something we do with the Orbi's, so it would be great to see this on Meraki Go so we can use it in more situations.
