Distance between APs
Can anyone tell me what might be the max distance between AP's?
I'm aware that there are a big number of factors that can make this change but just want to understand if this can be a suitable solution. I have to connect 2 AP's that are 3 brick walls away and 15 meters distance.
RR
Accepted Solutions
Re: Distance between APs
Hi Rui!
You're correct, there are a lot of factors that decide this. All sorts of environmental interference can have a negative impact on any RF signal.
I have a GR10 about 10 meters from my desk, going through 3 walls, steel filing cabinets, and an oak credenza. It's at about -60 dBm, which is strong enough to support a mesh network.
Vincent
2 REPLIES 2
Hi Rui!
Vincent
This is good information 🙂
Many thanks for your feedback @VincentPanico
