Central Management?
MFarmer
Central Management?
Looking at the Go line for executive home setups for some of our larger customers, have some basic 'how would you centrally manage this' type questions - any feedback is welcome.
It looks like the Meraki GO line does not snap into the same Meraki central management console is that true?
Is there any shared management of the Meraki GO line?
Is there any API to pull data or generate alerts out of the Meraki GO management/monitoring?
Is there a web console for the Meraki Go or is it purely on a mobile / tablet device?
Roska
Meraki Go/Meraki Enterprise Positioning document is out there somewhere in the internet. You might want to consult a partner shown on www.meraki-go.com buy section depending on your geo.
GO app only available App / Play stores.
Yes, built in app.
No
Is there a web console for the Meraki Go or is it purely on a mobile / tablet device? Solely app for management.
Hope it helps.
1 REPLY 1
Roska
Yes, built in app.
No
Hope it helps.
