Noticed a typo in a Knowledge Base Article
Noticed there is a small typo in a database article:Capture.PNG
In the table of contents, step 2 has both 2 and 3 listed making the remainder of the list be off by one number. Didn't know who to contact at Meraki about it, so I thought I'd post here since @CarolineS and @MerakiDave are so active.
Accepted Solutions
Re: Noticed a typo in a Knowledge Base Article
Hey @Mr_IT_Guy,
That's me. I fixed it, thanks very much for the suggestion.
There was a mis-labeled header there.
If you ever want to point out a suggestion, feel free to @me or DM me.
Cameron Moody | Documentation Manager, Cisco Meraki
9 REPLIES 9
Thanks @Mr_IT_Guy I'll bounce this to the documentation team!
Hey @Mr_IT_Guy,
Seems that MR42E and MR53E product pages have mixed ordering info on skus: MR42E -> MR53E-HW and vice versa.
https://meraki.cisco.com/products/wireless/mr42e#tech-specs
https://meraki.cisco.com/products/wireless/mr53e
You're correct, thank you for pointing that out! I've forwarded a message to the team responsible for those pages.
I just found another typo. On the MR74 datasheet:
Features section:
 MR74 TypoMR74 Typo
Regards!
@David-Ludo I sent that along to our datasheet team for an update, thanks for pointing that out!
A very minor typo I spotted is on the MX250 & MX450 product pages.
Under Highlights > Advanced security services it lists "Cisco Threat Grid1" - I think it should be a 2, not 1.
1 Requires Advanced Security License
2 Requires additional licensing for Threat Grid Cloud
All the other product pages have 2, with the exception of the MX400/600 which I believe do not support Threat Grid.
Ah, yes you're correct. Thanks @StevenWelsby, I forwarded a request to fix that to our main site team.
Also, for future corrections and issues, please feel free to message me directly.
