Meraki and California power outages
Sorry if this is a stupid question but since Meraki is based in California, and they have power outages, will it affect the Meraki Cloud?
I didn’t see anything on the forum.
Accepted Solutions
Re: Meraki and California power outages
Also note there are shards all around the world.  Your organisation tends to go on the shard closest to you.
So at worst it would only be orgs in that one geography at worst that would be affected.
6 REPLIES 6
No issues have come up in the past.
I’m sure  Meraki have back ups just in case.
Ok thanks. Just want to be ready just in case.
I just want to add to what @PhilipDAth already clarified. Our data centers are distributed geographically and are redundantly designed to provide disaster recovery in cases of emergency. Rest assured, you are in safe hands 🙂
Cheers!
Raj
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
Any residual doubt as to resilience - consult Chicken Little - (note the Meraki Corporate outfit and spectacles - obviously a longtime staffer)ChickenLittle01[1].jpg
