Port ESP IP protocol 50 test failed
FishMan
i have a juniper VPN need to install, a testing tool to test for
1. Port UDP/IKE 500: OK
2. Port UDP/NAT-T 4500: OK
3. Port ESP IP protocol 50: FAILED
can someone help why port ESP IP protocol 50: FAILED and how to fixed
Regards
7 Replies 7
KarstenI
Is your VPN gateway behind a NAT or PAT gateway? Then you don't need IP/50. And with PAT it typically can't be forwarded as there are no ports to translate.
FishMan
Thanks Karstenl
currently i use port forwarding
but they need to make sure that all testing ok with no failed, how could I get this done
Regards
KarstenI
Then you probably have to configure a 1:1 NAT with a free IP and forward all traffic.
FishMan
Hi Karsrenl
can you guide how to do 1:1NAT
Regards
KarstenI
FishMan
i am looking forward on how to allow /16 range to one private ip address using 1:1NAT
Regards
KarstenI
Where does this /16 come from? If you have one VPN gateway you need one IP address.
