I am starting a FortiNAC deployment project on a network that uses Cisco Meraki MS series, the problem I encountered is that the alert menu does not show the option "Clients connected or disconnected from LAN".
This would be the initial step to detect a new device on the network and then start the NAC filters.
Can you guide me if it is possible to enable this option in the alerts panel?
Thanks.
