Meraki WiFi6E Roaming Delay
Lhb
Just browsing
hello.
I have some questions during the WiFi6E test and would like to receive your guidance.
We install two CW9164I models to conduct a WiFi6E Roaming test, but sometimes a delay occurs in probe response.
I am curious whether the delay occurs in the Meraki AP, or the delay that occurs in the terminal or the network environment being tested.
Anyone who knows please respond.
2 Replies 2
What method of authentication are you using?  WPA3-SAE, WPA3-Enterprise, something else?
Is the management interface of both APs in the same VLAN (they need to exchange roaming info)?  Make sure you are not using any switch security features that restrict traffic between the ports (such as isolated ports).
Are you running current stable or better firmware on the APs?
Is your test client using up-to-date WiFi drivers?
Were the test clients plugged into the mains at the time with a good state of charge to prevent them from enabling WiFi power-saving features?
