Meraki MR36
Surya10101
Meraki MR36
I need to know how many concurrent users can connect in the MR36 and where can I found that documents regarding users?
This is nothing to do with the AP, and everything to do with the available airtime in the RF spectrum.  If you want the best performance, disable 2.4Ghz to increase available airtime.
Assuming you have good clear WiFi channels then some tips ...
10 to 15 users per AP will give you excellent performance.
15 to 30 users per AP will give you good performance.
30 to 50 low volume users per AP will work but throughput will be low.  Forget about using video.
50 to 127 users - will work but will be absolutely horrible.  People won't want to use the WiFi.  But if all you care about is how many people can connect - then you can use these numbers.  To stand any kind of chance, you will have to insist on users only having the latest devices with support for the latest WiFi standards and you will 100% have to disable 2.4Ghz.
7 Replies 7
DarrenOC
Good Morning @Surya10101
Please take. Read through:
https://documentation.meraki.com/MR/Wi-Fi_Basics_and_Best_Practices/Approximating_Maximum_Clients_pe...
These are theoretical limits
Surya10101
Is it approximate value?
Any body please tell the practical users and documentations provided from meraki.
DarrenOC
Here’s an old document for the second generation APs i.E MR33’s
https://telecom4good.org/wp-content/uploads/2019/06/Cisco-Meraki-MR-Access-Point-Comparison-Chart.pd...
SivaPrakashE
is meraki provided this?
Surya10101
if meraki provided this where is the updated version of this?
AmyReyes
Community Manager
Community Manager
Hi @Surya10101, Meraki no longer publishes this information because there are many variables that can affect limits, and they will vary based on your environment and other factors.
Your best bet is to talk to the Sales team. You can share details about your unique environment and needs, and they will be able to tell you more specifically what to expect.
You can find your country's sales number on the page here: https://meraki.cisco.com/form/contact/
I hope that helps.
