Dear All,
we have a ssid with authentcating method with PSK, and i see there are many authenticating error logs with below, just wonder how do i fix such issue ? any help would be appreicated
reason='eapol_timeout' radio='1' vap='3' channel='161' rssi='27'
Keith
What version of MR firmware are your APs on? The 802.11r Is enabled?
version in MR 27.7.1, and 802.11r has enabled
is it suggested to turn off 802.11r ?
Yep, 🙂
So this issue was related with 802.11r enabled ? So I will try to disable it and monitor the result
It can be a possibility.
i have disabled 802.11r but i still receiving below warning any idea ?
auth_mode='wpa3-psk' error_code='30' radio='1' vap='3' channel='100' rssi='31'
auth_mode='wpa2-psk' reassoc='1' error_code='30' radio='1' vap='3' channel='100' rssi='43'
Mon Oct 10, 2022, 11:20:36 | 42:c8:b9:35:f9:f3 | SSO | Association | auth_mode='wpa3-psk' error_code='30' radio='1' vap='3' channel='100' rssi='31' |
Mon Oct 10, 2022, 11:18:38 | 4e:3c:ff:9a:9b:64 | SSO | Association | auth_mode='wpa2-psk' reassoc='1' error_code='30' radio='1' vap='3' channel='100' rssi='43' |
Are you using PSK with WP3? Is it possible change it for PSK/WP2?
Let me try that and monitor for status
just wonder if i changed from WP3 to PSK/WP2, client devices will need to re-login again ?
Nope, the PSK key is saved.
