Search instead for
Apple TV - Home Sharing Not Working
Hi All,
My Network isn't allowing Home Sharing on the Apple TV, I removed the CISCO Network and replaced with a simple Vodafone Router and it works fine.
Please any advice would be great.
Thanks.
C.
Re: Apple TV - Home Sharing Not Working
Wired or wireless? Did you have the SSID in NAT mode?
Do you have just a single Vlan?
I put the WiFi into Bridge Mode as advised my Meraki Support and it worked first Time.
Thanks for your help!
C.
I have Single never used a VLAN,
C.
Have you turned on rendezvous support?
Robin St.Clair
