Wireless SSID pre-shared key (PSK) question
Tim_Rdown
Just browsing
Hi All
Probably a daft question. We have a SSID that uses a pre-shared key pushed out to our mobile devices via an Intune config policy. We want to change the pre-shared key and were wondering if its possible to add an additional PSK to the SSID via the Meraki console so that we can change it in the Intune config policy so when the device picks it up it will drop off then reconnect using the new PSK.
Hope that makes sense
1 REPLY 1
Not that i know of.
But you can try to convert (or create a New ssid) the ssid to ipsk authentication.  Then its possible to assign more then one psk to the ssid.
https://documentation.meraki.com/MR/Encryption_and_Authentication/IPSK_Authentication_Without_RADIUS
