Windows Installer still not finished building after ~1 day
ksebion
I created a new network yesterday.
Also yesterday, I navigated to the Windows tab under Add devices.
As usual, the tab showed "Windows installer: Building...".
However, today the tab still shows "Windows installer: Building...".
Is there anyway to fix this?
Accepted Solutions
ksebion
Re: Windows Installer still not finished building after ~1 day
 I replied the following to support.
I don't really need support.
I need the Meraki website to work correctly.
There was a time when a Meraki employee did something to force all Windows installers to be rebuilt.
Can you just trigger the rebuild?
Also, is the free version of Meraki being turned off?
The following links seem to indicate that it is.
  https://community.meraki.com/t5/Endpoint-Management-Systems/SM-Legacy/m-p/15904
  https://community.meraki.com/t5/Endpoint-Management-Systems/Legacy-Enrollment-failing/m-p/17659
 The download of the Windows installer became available sometime after I sent the reply.
8 REPLIES 8
MacuserJim
Are you referring to a Windows installer for Systems Manager? Can you post a screenshot of what you are referring to?
ksebion
I think so.
MacuserJim
I think you are running the legacy Systems Manager, since it does not look anything like the current documentation or my dashboard. https://documentation.meraki.com/SM/Device_Enrollment/Enrolling_Devices  I would suggest reaching out to support and asking about that.
ksebion
Users of the legacy Systems Manager are not provided support according to support.
MacuserJim
Did they say anything about why you're on the legacy Systems Manger, is it an option for you to bump up to the current SM?
ksebion
I misspoke. We do not have support because we do not have a license to any Meraki devices.
We're on the legacy Systems Manger for the same reason.
MacuserJim
Makes sense. You could try building that installer using different browsers or maybe even try a different computer, but it might just be a bug that Meraki may or may not address.
ksebion
