Windows 10 (1809) clients not showing up in Meraki dashboard
SEFE
I've installed the latest Meraki client software but the PC is not showing up in the dashboard. Log shows the following errors:
do_blocking_wmi_query(): command=C:\WINDOWS\system32\cscript.exe //E:vbscript //Nologo C:\WINDOWS\TEMP\m_A4D10.tmp
fetch(): curl error 7 for url https://cf.meraki.com/cf/config?mac=......
fetch_config(): fetch() false
do_blocking_wmi_query(): command=C:\WINDOWS\system32\cscript.exe //E:vbscript //Nologo C:\WINDOWS\TEMP\m_a3FF6.tmp
fetch(): curl error 28 for url https://cf.meaki.com/cf/config?mac=....
I've found that curl error 7 means blocked HTTPS traffic, but this shows up regardless of if the local Windows firewall is enabled or not.
Anyone else experiencing the same issue?
2 Replies 2
mer_tech01
Meraki Alumni (Retired)
Hi SEFE,
I think this was a backend issue. The issue is resolved now as I am able to see my Windows device online again.
--mer_tech01
SEFE
Thank you! Now everything works as it should.
