Widgets on the homescreen
Spartacs
Hello everbody,
i didn't found any option to deploy a widget to the homescreen of my iphones. Are there any options that i can automatically add widgets to my homescreenlayout?
My second problem is that i can't add widgets manually anymore when i defined a homescreenlayout and the profile is deployed.
Maybe anybody can give me some advice.
Thanks a lot 🙂
PaulF
Meraki Employee All-Star
Hi Spartacs
Apple currently only have the ability to manage apps, folders and web clips in the Home Screen Layout profile
Kind regards,
P
1 Reply 1
PaulF
Hi Spartacs
Kind regards,
P
