Webclips in multi-user mode
Mitch567
I'm having trouble trying to do something which I believe should be simple.
I've looked across google and some of the posts here but nothing definitive and tried their suggestions with no luck.
I basically use ASM and multiple users are able to use the shared ipads. I have setup profiles for home screen layouts and added all the required apps with no issues then got a request for a webclip to a website they use frequently.
I've tried a user and device profile.
I've tried setting the default app as Safari and Webclip.
I've made sure to allow webclips in the restrictions profile.
All I ever get is "Error: The payload type “com.apple.webClip.managed” is not permitted to be installed for the system in multi-user mode." I find it baffling that you can't simply add a shortcut to a device that multiple users use.
Is this really not possible?
What am I doing wrong?
Mitchell
1 Reply 1
vassallon
Based on what I see from Apple this should be supported.
https://support.apple.com/guide/deployment/web-clips-payload-settings-depbc7c7808/web
I don't use shared iPads so I've never tested it personally and Meraki's documentation doesn't address it at all.
https://documentation.meraki.com/SM/Profiles_and_Settings/Web_Clips_in_Systems_Manager
I did find this previous thread where someone was able to get it working.
https://community.meraki.com/t5/Mobile-Device-Management/Webclip-and-Ipad-Shared/m-p/76754
