Using Intune and not MDM
Jwiley78
We are using Intune to manage android devices.  I'm wondering if anyone has tried to push the Meraki client VPN with Intune to an Android device?  Is it possible?
You could change to using Cisco AnyConnect.  It is very flexible.  It's in both app stores.
https://documentation.meraki.com/MX/AnyConnect_on_the_MX_Appliance
It's an extra licence you have to buy, but it is relatively cheap and works so much better.
BlakeRichardson
The Meraki client VPN is simply an L2TP connection, most MDM support VPN profiles although you would be better to ask that question on an MS Intune forum.
Meraki's client VPN solution uses L2TP with IPsec encryption, supported by native clients built into Windows, Android, OS X, and iOS.
Jwiley78
Yeah, was going to hit the reddit and Intune also.  Not a huge issue if I can't get it to work but would save me a lot of time.  Thanks
Jwiley78
This is the option we are going with.  I have found it also fixes the IPv6 issue with Tmobile clients.  Just looking ot see if I can find a way to implement session timeouts now.
